HP Pavilion 15-au029ur Product Specifications
X5Z12EA
Intel® Core™ i5-6200U (2.3 GHz, up to 2.8 GHz, 3 MB cache, 2 cores)
8 GB DDR4-2133 SDRAM (1 x 8 GB)
Video graphics
  • NVIDIA® GeForce® 940MX (2 GB DDR3 dedicated)
  • Discrete
1 TB 5400 rpm SATA
Optical drive
SuperMulti DVD burner
39.6 cm (15.6") diagonal FHD SVA anti-glare WLED-backlit (1920 x 1080)
Keyboard
Pointing device
802.11b/g/n (1x1) and Bluetooth® 4.0 combo (Miracast compatible)
1 HDMI; 1 headphone/microphone combo; 1 USB 2.0; 2 USB 3.0; 1 RJ-45
38.3 x 24.3 x 2.25 cm
2.04 kg
65 W AC power adapter
2-cell, 41 Wh Li-ion
HP Wide Vision HD Camera with dual array digital microphone
B&O PLAY; HP Audio Boost; Dual speakers
FreeDOS 2.0
