HP LaserJet Enterprise, HP PageWide Enterprise MFP, HP OfficeJet Enterprise MFP - Customize the Home Screen, Display Settings or Language
Use the HP Embedded Web Server (EWS) to customize the control-panel display. Drag and drop applications to show, hide or reorder desired applications.
The following control-panel Home Screen options can be customized:
  • Which menu options display
  • The order in which the menu options display
  • The connection information that displays
  • Language selection and languages that display
  • Keyboard layouts
To restrict the ability to customize the control-panel display only to administrators, assign an administrator password.
This feature requires JavaScript®. Verify that JavaScript is enabled for the browser being used.
Customize the Control-Panel Home screen
  1. Using the top navigation tabs, click General.
  2. In the left navigation pane, click Control Panel Customization, and then complete one or more of the following procedures:
