    Fix HP Printer issue on macOS
Document ID: c05163480
Version: 1
Advisory: HP Z840 Workstation - Some Features Won't Be Available if Pairing an M6000 12GB and M6000 24GB Cards
Release date : 06-Jun-2016
Last updated : 06-Jun-2016
DESCRIPTION
If an NVIDIA Quadro M6000 12GB card, HP P/N 801196-002, is paired with an NVIDIA Quadro M6000 24GB card, HP P/N 844224-001, in the same system, certain dual-card features will not work. These features are SLI, Mosaic, and Quadro Sync.
Symptoms:
SLI, Mosaic, and Quadro Sync features will be unavailable.
SCOPE
Systems:
  • HP Z840 Workstation
Operating Systems:
  • Non-OS Specific
RESOLUTION
Only pair like model Nvidia M6000 cards; 2 x Nvidia M6000 12GB, HP P/N 801196-002 or 2 x Nvidia M6000 24GB, HP P/N 844224-001.
Hardware platforms affected : HP Z840 Workstation
Support Communication Cross Reference ID : IA05163480
