This document applies to HP ProBook 640 and 645 G2 notebooks.
warning:
Make sure the computer is disconnected from power before starting. Before starting, power off the computer and wait for components to cool before starting these procedures.
Procedures in this document are provided by HP for qualified service agents and as a courtesy to its customers. Removing and replacing parts and servicing internal components increases the risk of damaging the computer which might not be covered under warranty. Understand the risk and refer to the product's warranty before attempting to service the computer.
The video and graphics in this article depict a specific configuration of the notebook. These same removal and replacement procedures apply to all configurations of HP ProBook 640 and 645 G2 notebooks.
Step 1
Remove the bottom cover.
For detailed instructions, see Remove and Replace the Bottom Cover on HP ProBook 640 and 645 G2 Notebooks.
Step 2
Remove the battery.
For detailed instructions, see Remove and Replace the Battery HP ProBook 640 and 645 G2 Notebooks.
Step 3
Push both arms outward simultaneously to release the memory module to the spring tension position.
Step 4
Grasp the memory module by the edges and pull gently to remove it.
Step 5
Place the memory module in a static dissipative bag.
Step 1
Grasp the memory module by the edges and remove it from the static dissipative bag.
Step 2
Align the notch in the memory module with the key in the memory module slot on the system board.
Step 3
At an angle, gently insert the memory module into its slot on the system board.
Step 4
Press the memory module down to latch the arms. The clips will snap into place and hold the memory module in place.
Step 5
Replace the battery.
Step 6
Replace the bottom cover.
