HP ScanJet Pro 4500 fn1 - Use the scanning software (OS X)
The following topics describe how to scan using HP Easy Scan.
HP Easy Scan (OS X)
  1. Place the document on the scanner glass or in the document feeder.
  2. In the Applications folder, double click the HP Easy Scan icon.
  3. Confirm that ScanJet Pro 4500 fn1 is the selected scanner.
  4. Select a scan preset appropriate for the scan job.
  5. Click the Scan button.
  6. Once all the pages have been scanned, click File and then Save.
  7. Specify how and where the file is to be saved, and then click Save.
Scan from other applications (OS X)
An image can be scanned directly into any ICA-compliant application. In the application, look for options to import or acquire images from a scanner.
The HP software does not support TWAIN scanning. If the application has import or acquire functions but your HP scanner is not listed, the application might only be searching for scanners that support TWAIN.
Mobile scan
HP offers multiple mobile solutions to enable easy scanning to an HP Scanner from a laptop, tablet, smart phone, or other mobile device. For more information, go to www.hp.com/support/sj4500fn1.
Turn on Wi-Fi on the device before performing a mobile scan.
