HP ScanJet Pro 4500 fn1 - Scan to a computer from the touch panel
The following topics describe how to scan to a Windows or a Mac OS X computer.
Scan to a computer (Windows)
To scan to a computer, follow these steps:
  1. Install the HP Scan software on the computer that will receive the scans and enable the Scan to Computer option.
  2. Place the document on the flatbed glass or in the automatic document feeder.
  3. Press To Computer on the scanner touch panel.
  4. The scanner displays a list of computers that have the HP software installed and are enabled to receive scans from the scanner. Select a computer to receive the scan.
  5. Select the scan shortcut to be performed (e.g. Scan to PDF) on the scanner touch panel.
  6. Press Scan. The scan will be sent to the selected computer.
If there is paper loaded in one source but not the other, the scanner will only scan from that source. For example, if there is paper loaded in the automatic document feeder but not on the scanner glass, the scanner will scan from the automatic document feeder.
