HP ScanJet Pro 2500 f1, 3500 f1, 4500 fn1 - Scan driver and software support for OS X
This document applies to HP ScanJet scanners only. The list below provides the HP scan drivers and software available for each HP ScanJet to scan in OS X El Capitan (v10.11), OS X Yosemite (v10.10), and OS X Mavericks (v10.9).
HP ScanJet scan driver and software support
Legend
= Not available
= Available
= USB connection
= Network connection
= Wireless connection
AirPrint-capable1
Scanner software for OS X v10.9 and later
Connection requirements
HP ScanJet series
OS X v10.9+
Available Scan/Send solution
Install connection2
Scan connection3
ScanJet Pro 2500 f1
ICA4
HP Utility5
ScanJet Pro 3500 f1
ICA4
HP Easy Scan6
HP Utility5
ScanJet Pro 4500 fn1
ICA4
HP Easy Scan6
HP Utility5
1For AirPrint to work, the AirPrint-capable scanner and the Mac OS running v10.9 and later must be connected to the same local network.
2To install the driver, connect the scanner to the computer using a supported connection type. Some scanners do not support network or wireless installs. For these scanners, use a USB connection. Select scanners have wireless capability which will enable a wireless install.
3To scan, connect the scanner to the computer using a supported connection type. Some scanners do not support wireless scanning or scanning over a network. For these scanners, use a USB connection. Select scanners might have wireless capability, which will enable wireless scanning.
4The scanner provides a scanner driver for Mac OS X. This allows the scanner to be used with an ICA-compliant application, including the Image Capture and Preview applications that are already installed on a Mac OS X.
5Use the HP Utility to manage scanner settings.
6Use HP Easy Scan to scan documents and photos, and manage scan shortcuts.
