HP Notebook - 14-ac610tu Product Specifications
W6S70PA
Intel® Celeron® N3050 with Intel® HD Graphics (1.6 GHz, 2 MB cache, 2 cores)
4 GB DDR3L-1600 SDRAM (1 x 4 GB)
Video Graphics
Intel® HD Graphics
Hard Drive
500 GB 5400 rpm SATA
Optical drive
SuperMulti DVD burner
14" diagonal HD BrightView WLED-backlit (1366 x 768)
Keyboard
Island-style keyboard
Pointing device
Wireless Connectivity
802.11b/g/n (1x1) and Bluetooth® 4.0 combo (Miracast compatible)
External Ports
2 USB 2.0; 1 USB 3.0; 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
34.54 x 24.15 x 2.39 cm
Starting at 1.94 kg
45 W AC power adapter
4-cell, 41 Wh Li-ion
HP TrueVision HD Webcam (front-facing) with integrated digital microphone
DTS Studio Sound™; Dual speakers
HP Recovery Manager; HP Support Assistant
Pre-installed software
Adobe® Shockwave® Player; CyberLink PhotoDirector; CyberLink YouCam; Evernote; User Guide documentation; Dropbox; CyberLink Power Media Player; iPass
Buy Office
