HP LaserJet Enterprise M630, M830, HP Color LaserJet Enterprise M680, M880 And HP Enterprise OfficeJet X585 series - 31.13.00, 31.13.01, 31.13.02 and 31.13.14 Error
Issue:
Paper is jammed in the automatic document feeder (ADF).
The printer will display 31.13.XX Jam in ADF.
Solution:
Clear jams in the document feeder
The following information describes how to clear paper jams in the document feeder. When a jam occurs, the control panel displays an steps that assists in clearing the jam.
To see a video of how to remove paper jams in the ADF, go to:
  1. Lift the latch to release the document-feeder cover.
    Figure : Lift the latch
  2. Open the document-feeder cover.
    Figure : Open the document-feeder cover
  3. Lift the jam-access door, and remove any jammed paper.
    If necessary, rotate the green wheel at the front of the document feeder to remove jammed paper.
    Figure : Remove jammed paper
  4. Press on the door next to the document-feeder rollers to make sure it is closed completely.
    Figure : Close the roller door
  5. Lift the document-feeder input tray.
    Figure : Lift the document-feeder tray
  6. Squeeze inward on the two slots at each end of the backside-background selector assembly.
    Figure : Release the backside-background selector assembly
  7. Remove the backside-background selector assembly by pulling it out.
    Figure : Remove the backside-background selector assembly
  8. Remove any jammed paper.
    Figure : Remove the jammed paper
  9. Reinstall the backside-background selector assembly by sliding it in until it locks into place.
    Figure : Install the backside-background selector assembly
  10. Lower the document-feeder input tray.
    Figure : Lower the document-feeder tray
  11. Close the document-feeder cover.
    Figure : Close the document-feeder cover
To avoid jams, make sure the guides in the document-feeder input tray are adjusted tightly against the document.
Remove all staples and paper clips from original documents.
Original documents that are printed on heavy, glossy paper can jam more frequently than originals that are printed on plain paper.
