Document ID: c05083050
Version: 1
Advisory: HP Elite x2 1012 G1 - SD Card Slot Damaged By Inserting The SD Card Tray Upside Down
Release date : 13-Apr-2016
Last updated : 13-Apr-2016
DESCRIPTION
Inserting the SD card tray upside down can damage the slot. Care must be taken to insert the SD card tray properly.
Figure 1. Correct (checkmark) and incorrect (X) tray insertion
NOTE: computers manufactured beginning 01 September 2016 and later have a design change that prevents improper insertion of the SD card tray.
SCOPE
Computer:
HP Elite x2 1012 G1
Computer serial number range:
xxx634xxxx and lower
NOTE: a design change beginning with serial number xxx635xxxx prevents the issue
RESOLUTION
To avoid damage to the SD card tray and slot, take care to orient the SD card tray properly when inserting the tray into the slot:
Figure 2. Orient the SD card tray so that the pinhole (1) is oriented toward the USB-C port (2).
For more information on inserting and removing SD cards, refer to Section 7 of the user guide:
Hardware platforms affected : HP Elite x2 1012 G1
Support Communication Cross Reference ID : IA05083050
