When the monitor is hot plugged and unplugged, several display issues are exhibited. This issue occur when the HP Z232 monitor OSD (On Screen Display) option is set to
Always active.
The computer may exhibit one or more of the following symptoms:
- The display panel flashes or flickers.
- No video is displayed. (Display is lost)
- An error may be displayed on a blue screen.
The following error may be displayed on a blue screen:
SYSTEM_SERVICE_EXCEPTION (nvlddmkm.sys)
Figure 1: Error is displayed on a blue screen:
