HP Pavilion 25cw 25-inch IPS LED Backlit Monitor - Product Specifications
The HP Pavilion 25cw is a 63.5 cm (25 in) IPS LED Backlit Monitor.
Figure : HP Pavilion 25cw Monitor
The HP Pavilion 25cw Monitor
J7Y64AA
Technical specifications
LED feature
Specification
Display size
63.5 cm (25 in) diagonal
Display type
IPS with LED Backlight
Panel active area
55.3 x 30.1 cm (21.8 x 11.9 in)
Brightness
250 cd/m2
Color gamut
72%
Color support
Up to 16.7 million colors supported through FRC technology
Pixel pitch
0.288 x 0.286 mm
88.1 PPI
Inputs
1 VGA
2 HDMI
HDCP support on digital inputs
Viewing angle
Horizontal viewing angle (typical): 178 degrees
Vertical viewing angle (typical): 178 degrees
Recommended resolution (H x V)
1920 x 1080 @ 60 Hz (Full HD)
Aspect ratio
16:9
Static contrast ratio
Up to 1000:1
Dynamic contrast ratio
Up to 5,000,000:1
Response time
7 ms (OD)
Power consumption
30 Watts max
Tilt
-2 to +25 degrees
Power Supply
External, 100 to 240 VAC, 50/60 Hz
Base
Detachable
Dimensions
W x D x H (unpacked):
57.7 x 16.5 x 42.4 cm (22.7 x 6.5 x 16.7 in)
Unpacked: 4.8 Kg (10.6 lbs)
