HP Pavilion 22cw 21.5-inch IPS LED Backlit Monitor - Product Specifications
The HP Pavilion 22cw is a 54.6 cm (21.5 in) IPS LED Backlit Monitor.
Figure : HP 22cw Monitor
The HP 22cw Monitor
J7Y66AA
Technical specifications
LED feature
Specification
Display size
54.6 cm (21.5 in) diagonal
Display type
IPS with LED Backlight
Panel active area
47.6 x 26.8 cm (18.7 x 10.6 in)
Brightness
250 nits
Color gamut
72%
Pixel pitch
0.248mm
102 PPI
Inputs
1 VGA
1 HDMI
HDCP support on digital inputs
Viewing angle
Horizontal viewing angle (typical): 178 degrees
Vertical viewing angle (typical): 178 degrees
Recommended resolution (H x V)
1920 x 1080 @ 60 Hz (Full HD)
Aspect ratio
16:9
Static contrast ratio
Up to 1000:1
Dynamic contrast ratio
Up to 5,000,000:1
Response time
7 ms gray to gray
Power consumption
24 Watts max
Tilt
-2 to +25 degrees
Power Supply
External, 100 to 240 VAC
Base
Detachable
Dimensions
W x D x H (unpacked):
49.8 x 15.0 x 38.4 cm (19.6 x 5.9 x 15.1 in)
Unpacked: 3.9 Kg (8.5 lbs)
