    Apache Log4j Update
HP Spectre x360 - 13-4108ng (ENERGY STAR) Product Specifications
W2V95EA
Intel® Core™ i7-6500U with Intel® HD Graphics 520 (2.5 GHz, up to 3.1 GHz, 4 MB cache, 2 cores)
8 GB DDR3L-1600 SDRAM (onboard)
Video Graphics
33.8 cm (13.3") diagonal QHD IPS LED-backlit touch screen (2560 x 1440)
Keyboard
Full-size island-style backlit
Pointing device
HP Control Zone Trackpad
Wireless Connectivity
802.11a/b/g/n/ac (2x2) and Bluetooth® 4.0 combo (Miracast compatible)
External Ports
1 HDMI; 1 headphone/microphone combo; 3 USB 3.0 (HP USB Boost); 1 Mini DisplayPort
32.5 x 21.8 x 1.6 cm
1.45 kg
45 W AC power adapter
HP TrueVision Full HD WVA Webcam (front-facing) with integrated dual digital microphones
Bang & Olufsen; Dual speakers
HP Lounge
Pre-installed software
Netflix; Skype
