HP Notebook - 14-ac604tu Product Specifications
W0H76PA
Intel® Pentium® N3700 with Intel® HD Graphics (1.6 GHz, up to 2.4 GHz, 2 MB cache, 4 cores)
2 GB DDR3L-1600 SDRAM (1 x 2 GB)
Video Graphics
Intel HD Graphics
Hard Drive
500 GB 5400 rpm SATA
Optical drive
SuperMulti DVD burner
14" diagonal HD BrightView WLED-backlit (1366 x 768)
Keyboard
Island-style keyboard
Pointing device
Wireless Connectivity
802.11b/g/n (1x1) (Miracast compatible)
External Ports
2 USB 2.0; 1 USB 3.0; 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
34.54 x 24.15 x 2.39 cm
1.94 kg
45 W AC power adapter
4-cell, 41 Wh Li-ion
HP TrueVision HD Webcam (front-facing) with integrated digital microphone
DTS Studio Sound™; Dual speakers
Pre-installed software
Adobe® Shockwave® Player; CyberLink PhotoDirector; CyberLink YouCam; Evernote; User Guide documentation; Dropbox; CyberLink Power Media Player; iPass
Buy Office
HP Recovery Manager; HP Support Assistant
