HP Pavilion Gaming Notebook - 15-ak031tx Product Specifications
T0Z18PA
Intel® Core™ i5-6300HQ with Intel® HD Graphics 530 (2.3 GHz, up to 3.2 GHz, 6 MB cache, 4 cores)
Intel HM170
4 GB DDR3L SDRAM (1 x 4 GB)
Video Graphics
NVIDIA GeForce GTX 950M (4 GB DDR3L dedicated)
Hard Drive
1 TB 5400 rpm SATA
Optical drive
SuperMulti DVD burner
15.6" diagonal FHD anti-glare WLED-backlit (1920 x 1080)
Keyboard
island-style backlit keyboard with integrated numeric keypad
Pointing device
Wireless Connectivity
802.11a/b/g/n/ac (1x1) and Bluetooth® 4.0 combo (Miracast compatible)
External Ports
2 USB 3.0; 1 USB 2.0; 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
38.45 x 26.51 x 2.88 cm
Starting at 2.32 kg
90 W AC power adapter
4-cell, 48 Wh Li-ion
HP TrueVision HD Webcam (front-facing) with integrated dual array digital microphone
B&O PLAY; Dual speakers
Buy Office
HP Support Assistant; HP Recovery Manager; HP CoolSense; HP 3D DriveGuard
Pre-installed software
CyberLink YouCam; CyberLink PowerDirector; CyberLink PhotoDirector; Adobe® Shockwave® Player; CyberLink Power Media Player; User Guide documentation; iPass; Evernote; Dropbox
