HP Officejet Pro 8700 Printers - Extra Pages Feed Through the Printer
This document is for HP Officejet Pro 8710, 8715, 8720, 8725, and 8740 All-in-One printers.
The printer feeds more than one page at a time when you try to print, scan, fax, or copy.
If the issue is limited to the automatic document feeder (ADF), skip to the step to clean the ADF.
The printer in the images might look different than your printer, but the steps are the same.
Step 1: Check the condition of the paper
Remove the input tray, and then check the condition of the paper.
Step 2: Clean the separation pad, plate, and paper pick roller
Dust, paper fiber, or other debris might accumulate on the separation pad, separation plate, or paper pick roller and cause paper feed issues. Clean the input tray separation pad, the separation plate, and the paper pick roller inside the printer, and then try to print again.
  1. Gather the following materials:
    • Lint-free cotton swabs
    • Distilled, filtered, or bottled water (tap water might damage the printer)
  2. Turn off the printer, and then disconnect the power cord and any other cables.
  3. Pull out the input tray, and then remove any paper in it.
    Figure : Pulling out the input tray
    Pulling out the input tray.
  4. Inspect the separation pad. If dirt or debris is found, lightly dampen a clean, lint-free cotton swab with bottled or distilled water, squeeze any excess liquid from the swab, and then clean the pad.
    Figure : Input tray separation pad
    Do not reinsert the input tray at this time.
  5. Turn the printer so that the rear access door faces you.
  6. Press the two tabs inward to open the rear access door.
    Figure : Opening the rear access door
    Image: Opening the rear access door
  7. Press the two buttons on the paper path cover, and then pull the cover out of the printer.
    Figure : Removing the paper path cover
  8. Locate the paper pick roller. The roller is behind the white separation plate shown in the following image.
    Figure : Locate the paper pick roller
    Find the paper pick roller
  9. Lightly dampen a clean, lint-free cotton swab with bottled or distilled water, and then squeeze any excess liquid from the swab.
  10. Pull the white separation plate outward as far as possible.
    Figure : Pulling out the white separation plate
    Pulling out the white plate
  11. Use the damp swab to clean the inside of the separation plate.
  12. Clean the paper pick roller with another damp swab, using your finger to push up and rotate the roller until you finish.
    You might have to push up firmly at first to rotate the roller.
    Pushing down to rotate the paper pick roller might result in damage to the printer.
  13. Allow the separation plate and pick roller to dry completely (approximately 10 minutes).
  14. Insert the paper path cover back into the printer.
  15. Close the rear access door.
  16. Turn the printer so that the control panel faces you.
  17. Slide the input tray back into the printer.
  18. Reconnect the power cord and any other cables to the rear of the printer, and then turn on the printer.
Try to print.
  • If multiple pages continue to feed into the printer at the same time, skip to the step to service the printer.
  • If the issue no longer occurs with the printer, but multiple pages feed through the ADF, continue to the next step.
  • If both the printer and the ADF pick paper one sheet at a time, you can stop troubleshooting.
Step 3: Clean the ADF rollers and separator pads
Dirt or debris on the ADF rollers or separator pad might transfer to the scanned item, causing streaks or lines.
    • Several clean, lint-free cloths, or any cloth that does not come apart or leave fibers
  2. Remove any documents from the ADF tray.
  3. Turn off the printer, and then disconnect the power cord from the rear of the printer.
  4. Lift the ADF cover.
    Figure : Lifting the ADF cover
    Lift the ADF cover.
  5. Locate the pick rollers and the separator pad.
      Figure : Locations of the pick rollers and the separator pad
      Locations of the pick rollers and separator pad.
    1. Pick rollers
    2. Separator pad
  6. Lightly dampen a clean lint-free cloth with distilled or bottled water, and then squeeze any excess liquid from the cloth.
  7. Use the damp cloth to remove residue from the separator pad.
    Figure : The separator pad
    Photograph of the separator pad.
  8. Use the damp cloth to remove residue from the pick rollers.
    Figure : The pick rollers
    Photograph of the pick rollers.
  9. Dry the pick rollers and the separator pad with a clean, dry, lint-free cloth.
  10. Close the ADF cover.
Try to copy using the ADF. If the issue persists, continue to the next step.
Step 4: Service the printer
If none of the previous steps resolved the issue, service the printer.
Service or replace your HP product if the issue persists after completing all the preceding steps.
Go to Contact HP Customer Support to schedule a product repair or replacement. If you are in Asia Pacific, you will be directed to a local service center in your area.
To confirm your warranty status, go to HP Product Warranty Check. Repair fees might apply for out-of-warranty products.
