HP ENVY x360 - 15-w100nm (ENERGY STAR) Product Specifications
P0T16EA
Intel® Core™ i7-6500U with Intel® HD Graphics 520 (2.5 GHz, up to 3.1 GHz, 4 MB cache, 2 cores)
4 GB DDR3L SDRAM (1 x 4 GB)
Video Graphics
NVIDIA GeForce 930M (2 GB DDR3L dedicated)
Hard Drive
500 GB 5400 rpm SATA
39.6 cm (15.6") diagonal FHD IPS WLED-backlit touch screen (1920 x 1080)
Keyboard
Full-size backlit keyboard with integrated numeric keypad
Pointing device
Wireless Connectivity
802.11a/b/g/n/ac (2x2) and Bluetooth® 4.0 combo (Miracast compatible)
Integrated 10/100/1000 Gigabit Ethernet LAN
External Ports
1 HDMI; 1 headphone/microphone combo; 1 USB 2.0; 2 USB 3.0 (1 HP USB boost); 1 RJ-45
38.2 x 25 x 2.39 cm
2.29 kg
65 W AC power adapter
3-cell, 48 Wh Li-ion prismatic
HP TrueVision HD Webcam (front-facing) with integrated dual array digital microphone
Bang & Olufsen with 2 speakers
Pre-installed software
Evernote; Skype
HP 3D DriveGuard
