HP Pavilion Gaming Notebook - 15-ak196ur (ENERGY STAR) Product Specifications
P3M07EA
Intel® Core™ i7-6700HQ with Intel® HD Graphics 530 (2.6 GHz, up to 3.5 GHz, 6 MB cache, 4 cores)
Intel HM170
8 GB DDR3L SDRAM (1 x 8 GB)
Video Graphics
NVIDIA GeForce GTX 950M (4 GB DDR3L dedicated)
Hard Drive
1 TB 5400 rpm SATA
Optical drive
SuperMulti DVD burner
39.6 cm (15.6") diagonal FHD anti-glare WLED-backlit (1920 x 1080)
Keyboard
Full-size island-style backlit with numeric keypad
Pointing device
Wireless Connectivity
802.11b/g/n (1x1) and Bluetooth® 4.0 combo (Miracast compatible)
External Ports
1 HDMI; 1 headphone/microphone combo; 1 USB 2.0; 2 USB 3.0; 1 RJ-45
38.45 x 26.51 x 2.88 cm
2.32 kg
90 W AC power adapter
4-cell, 48 Wh Li-ion
HP TrueVision HD Webcam (front-facing) with integrated dual array digital microphone
B&O PLAY; Dual speakers
HP Lounge; HP 3D DriveGuard
Pre-installed software
Evernote; Skype; Unigine Heaven Benchmark; Unigine Valley Benchmark
