HP Pavilion Notebook - 17-g150ur (ENERGY STAR) Product Specifications
N7K01EA
AMD Quad-Core A4-6210 APU with Radeon R3 Graphics (1.8 GHz, 2 MB cache)
4 GB DDR3L SDRAM (1 x 4 GB)
Video Graphics
AMD Radeon R3 Graphics
Hard Drive
500 GB 5400 rpm SATA
Optical drive
SuperMulti DVD burner
43.9 cm (17.3") diagonal HD+ BrightView WLED-backlit (1600 x 900)
Keyboard
Full-size island-style keyboard with integrated numeric keypad
Pointing device
Wireless Connectivity
802.11b/g/n (1x1) and Bluetooth® 4.0 combo (Miracast compatible)
External Ports
1 HDMI; 1 headphone/microphone combo; 1 USB 2.0; 2 USB 3.0; 1 RJ-45
41.88 x 28.68 x 2.71 cm
2.79 kg
45 W AC power adapter
4-cell, 41 Wh Li-ion
HP TrueVision HD Webcam (front-facing) with integrated dual array digital microphone
B&O PLAY with 2 speakers
HP Lounge; HP 3D DriveGuard
Pre-installed software
Evernote; Skype
