N7H18EA
HP Pavilion Notebook - 15-ab227ur (ENERGY STAR)
Intel® Core™ i3-5020U with Intel® HD Graphics 5500 (2.2 GHz, 3 MB cache, 2 cores)
6 GB DDR3L SDRAM (1 x 2 GB, 1 x 4 GB)
Video Graphics
AMD Radeon R7 M360 Graphics (2 GB DDR3 dedicated)
Hard Drive
500 GB 5400 rpm SATA
Optical drive
SuperMulti DVD burner
39.6 cm (15.6") diagonal FHD anti-glare WLED-backlit (1920 x 1080)
Keyboard
Full-size island-style keyboard with integrated numeric keypad
Pointing device
Wireless Connectivity
802.11b/g/n (1x1) and Bluetooth® 4.0 combo (Miracast compatible)
External Ports
1 HDMI; 1 headphone/microphone combo; 1 USB 2.0; 2 USB 3.0; 1 RJ-45
38.45 x 26.11 x 2.52 cm
2.29 kg
65 W AC power adapter
4-cell, 41 Wh Li-ion
HP TrueVision HD Webcam (front-facing) with integrated dual array digital microphone
B&O PLAY; Dual speakers
- ${title}
- ${title}
- ${title}
- ${title}
HP Pavilion Notebook - 15-ab227ur (ENERGY STAR) Product Specifications
Pre-installed software
Evernote; Skype
HP Lounge; HP 3D DriveGuard
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Serbia
- ${title}
hp-hero-support-search
- ${title}
