P3L97EA
HP ENVY Notebook - 17-n102nn (ENERGY STAR)
Intel® Core™ i7-6700HQ with Intel® HD Graphics 530 (2.6 GHz, up to 3.5 GHz, 6 MB cache, 4 cores)
Intel HM170
16 GB DDR3L SDRAM (2 x 8 GB)
Video Graphics
NVIDIA GeForce GTX 950M (4 GB DDR3L dedicated)
Hard Drive
1 TB 5400 rpm SATA SSHD
Optical drive
SuperMulti DVD burner
43.9 cm (17.3") diagonal FHD IPS anti-glare WLED-backlit (1920 x 1080)
Keyboard
Full-size island-style backlit with numeric keypad
Pointing device
Wireless Connectivity
802.11a/b/g/n/ac (2x2) and Bluetooth® 4.0 combo (Miracast compatible)
Integrated 10/100/1000 Gigabit Ethernet LAN
External Ports
1 HDMI; 1 headphone/microphone combo; 4 USB 3.0 (1 HP USB Boost); 1 RJ-45
41.5 x 28.13 x 2.93 cm
2.82 kg
120 W AC power adapter
6-cell, 62 Wh Li-ion
HP TrueVision HD Webcam (front-facing) with integrated dual array digital microphone
Bang & Olufsen with 4 speakers and 1 subwoofer
- ${title}
- ${title}
- ${title}
- ${title}
HP ENVY Notebook - 17-n102nn (ENERGY STAR) Product Specifications
Pre-installed software
Evernote; Skype
HP SimplePass; HP 3D DriveGuard
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Serbia
- ${title}
hp-hero-support-search
- ${title}
