HP ENVY Notebook - 13-d006na (ENERGY STAR) Product Specifications
N9S66EA
Intel® Core™ i3-6100U with Intel® HD Graphics 520 (2.3 GHz, 3 MB cache, 2 cores)
4 GB DDR3L SDRAM (onboard)
Video Graphics
Hard Drive
128 GB M.2 SSD
33.8 cm (13.3") diagonal FHD IPS anti-glare WLED-backlit (1920 x 1080)
Keyboard
Full-size island-style backlit
Pointing device
Wireless Connectivity
802.11a/b/g/n/ac (2x2) and Bluetooth® 4.0 combo (Miracast compatible)
External Ports
1 HDMI; 1 headphone/microphone combo; 3 USB 3.0 (1 HP USB Boost)
32.65 x 22.6 x 1.29 cm
1.27 kg
45 W AC power adapter
3-cell, 45 Wh Li-ion polymer
HP TrueVision HD Webcam (front-facing) with integrated dual array digital microphone
Bang & Olufsen; Dual speakers
HP Lounge; HP SimplePass
Pre-installed software
Evernote; Netflix; Skype
