HP Pavilion Notebook - 17-g102no (ENERGY STAR) Product Specifications
P1R63EA
Intel® Core™ i7-6500U with Intel® HD Graphics 520 (2.5 GHz, 4 MB cache, 2 cores)
Flash cache
8 GB
12 GB DDR3L SDRAM (1 x 4 GB, 1 x 8 GB)
Video Graphics
NVIDIA GeForce 940M (4 GB DDR3L dedicated)
Hard Drive
1 TB 5400 rpm SATA SSHD
Optical drive
SuperMulti DVD burner
43.9 cm (17.3") diagonal FHD IPS anti-glare WLED-backlit (1920 x 1080)
Keyboard
Full-size island-style keyboard with integrated numeric keypad
Pointing device
Wireless Connectivity
802.11a/b/g/n/ac (1x1) and Bluetooth® 4.0 combo (Miracast compatible)
External Ports
1 HDMI; 1 headphone/microphone combo; 1 USB 2.0; 2 USB 3.0; 1 RJ-45
41.88 x 28.68 x 2.71 cm
2.79 kg
65 W AC power adapter
4-cell, 41 Wh Li-ion
HP TrueVision HD Webcam (front-facing) with integrated dual array digital microphone
B&O PLAY with 2 speakers
HP Games by WildTangent; HP Lounge; HP 3D DriveGuard
Pre-installed software
CyberLink PowerBackup; Evernote; Netflix; Skype
