HP ENVY Notebook - 15-ah151sa (ENERGY STAR) Product Specifications
P0U49EA
AMD Quad-Core A10-8700P APU with Radeon R6 Graphics (1.8 GHz, 2 MB cache)
8 GB DDR3L SDRAM (1 x 8 GB)
Video Graphics
AMD Radeon R6 Graphics
Hard Drive
1 TB 5400 rpm SATA
39.6 cm (15.6") diagonal HD BrightView WLED-backlit (1366 x 768)
Keyboard
Full-size island-style backlit with numeric keypad
Pointing device
Wireless Connectivity
802.11a/b/g/n/ac (1x1) and Bluetooth® 4.0 combo (Miracast compatible)
Integrated 10/100/1000 Gigabit Ethernet LAN
External Ports
1 HDMI; 1 headphone/microphone combo; 1 USB 2.0; 3 USB 3.0 (1 HP USB boost); 1 RJ-45
38.4 x 25.5 x 2.29 cm
2.12 kg
45 W AC power adapter
3-cell, 48 Wh Li-ion prismatic
HP TrueVision HD Webcam (front-facing) with integrated dual array digital microphone
Bang & Olufsen with 2 speakers and 1 subwoofer
HP Connected Drive; HP Lounge; HP 3D DriveGuard
Pre-installed software
Evernote; Netflix; Skype
McAfee LiveSafe
