HP Pavilion Notebook - 15-ab137ax Product Specifications
T9G50PA
AMD Quad-Core A10-8780P APU (2 GHz, up to 3.3 GHz, 2 MB cache)
4 GB DDR3L SDRAM (1 x 4 GB)
Video Graphics
AMD Radeon R7 M360 Graphics (2 GB DDR3 dedicated)
Hard Drive
2 TB 5400 rpm SATA
Optical drive
SuperMulti DVD burner
15.6" diagonal HD BrightView LED-backlit (1366 x 768)
Keyboard
Island-style backlit keyboard with integrated numeric keypad
Pointing device
Wireless Connectivity
802.11b/g/n (1x1) and Bluetooth® 4.0 combo (Miracast compatible)
External Ports
2 USB 3.0; 1 USB 2.0; 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
38.45 x 26.11 x 2.5 cm
Starting at 2.22 kg
65 W AC power adapter
4-cell, 41 Wh Li-ion
HP TrueVision HD Webcam (front-facing) with integrated dual array digital microphone
B&O PLAY; Dual speakers
HP Support Assistant; HP Recovery Manager; HP CoolSense; HP 3D DriveGuard
Pre-installed software
CyberLink YouCam; CyberLink PowerDirector; CyberLink PhotoDirector; Adobe® Shockwave® Player; CyberLink Power Media Player; User Guide documentation; iPass; Evernote; Dropbox
Buy Office
