This document is for HP OfficeJet 200, 200c, 202, 202c Mobile printers.
To set up a printer for the first time, remove the printer and all packing materials from the box, install the battery, connect the power cable, set control panel preferences, load paper, and then install the ink cartridges. After your printer is set up, download and install the latest print driver.
note:If you are looking for the printer software, go to 123.hp.com/OJ200.
