HP Notebook - 17-p128nf (ENERGY STAR) Product Specifications
V2H77EA
AMD Quad-Core A6-6310 APU with Radeon R4 Graphics (1.8 GHz, 2 MB cache)
6 GB DDR3L SDRAM (1 x 2 GB, 1 x 4 GB)
Video Graphics
AMD Radeon R4 Graphics
Hard Drive
1 TB 5400 rpm SATA
Optical drive
SuperMulti DVD burner
43.9 cm (17.3") diagonal HD+ BrightView WLED-backlit (1600 x 900)
Keyboard
Full-size island-style keyboard with integrated numeric keypad
Pointing device
Wireless Connectivity
802.11b/g/n (1x1) (Miracast compatible)
External Ports
1 HDMI; 1 headphone/microphone combo; 2 USB 2.0; 1 USB 3.0; 1 RJ-45
41.95 x 27.9 x 2.77 cm
2.82 kg
45 W AC power adapter
4-cell, 41 Wh Li-ion
VGA webcam (front-facing) with integrated digital microphone
DTS Studio Sound™ with 2 speakers
HP Games by WildTangent; HP Lounge; HP 3D DriveGuard
Pre-installed software
Evernote; Netflix; Skype
