HP Pavilion Notebook - 14-ab117tu Product Specifications
P3V24PA
Intel® Core™ i3-6100U with Intel® HD Graphics 520 (2.3 GHz, 3 MB cache, 2 cores)
4 GB DDR3L-1600 SDRAM (1 x 4 GB)
Video Graphics
Hard Drive
500 GB 5400 rpm SATA
Optical drive
SuperMulti DVD burner
14" diagonal HD BrightView LED-backlit (1366 x 768)
Display size (diagonal)
14"
Keyboard
Island-style keyboard
Pointing device
Wireless Connectivity
802.11b/g/n (1x1) and Bluetooth® 4.0 combo
External Ports
2 USB 3.0 (1 HP USB Boost); 1 USB 2.0; 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
34.54 x 24.25 x 2.5 cm
Starting at 1.96 kg
45 W AC power adapter
4-cell, 41 Wh Li-ion
B&O PLAY with 2 speakers
Buy Office
HP Support Assistant; HP Recovery Manager; HP CoolSense; HP 3D DriveGuard; HP Connected Drive
Pre-installed software
CyberLink YouCam; CyberLink PowerDirector; CyberLink PhotoDirector; Adobe® Shockwave® Player; CyberLink Power Media Player; User Guide documentation; iPass; Evernote; Dropbox
