HP Pavilion x360 - 11-k199ur (ENERGY STAR) Product Specifications
P3M03EA
Intel® Core™ M3-6Y30 with Intel® HD Graphics 515 (900 MHz, up to 2.2 GHz, 4 MB cache, 2 cores)
4 GB DDR3L SDRAM (onboard)
Video Graphics
Hard Drive
128 GB M.2 SSD
29.5 cm (11.6") diagonal HD IPS WLED-backlit touch screen (1366 x 768)
Keyboard
Full-size island-style keyboard
Pointing device
Wireless Connectivity
802.11b/g/n (1x1) and Bluetooth® 4.0 combo (Miracast compatible)
External Ports
1 HDMI; 1 headphone/microphone combo; 1 USB 2.0; 2 USB 3.0; 1 RJ-45
30.6 x 20.8 x 2.25 cm
1.37 kg
45 W AC power adapter
2-cell, 32 Wh Li-ion prismatic
HP TrueVision HD Webcam (front-facing) with integrated dual array digital microphone
B&O PLAY with 2 speakers
Pre-installed software
Evernote; Skype
HP Lounge
