HP ScanJet Pro 2500 - Product Specifications
Technical specifications
Automatic document feeder specifications:
Name
Input tray capacity
50 sheets of 75g/m2
Minimum paper size
148 x 89 mm
Maximum paper size
3100 x 216 mm
Minimum paper weight
60 g/m2
Maximum paper weight
105 g/m2
Minimum paper guiding space
89 mm
Supported operating systems
Windows 7
Windows 8
Windows 8.1
Windows 10
OS X Mavericks 10.9
OS X Yosemite 10.10
Product dimensions
Product dimensions
Height
Depth
Width
HP ScanJet Pro 2500 f1
122 mm
351 mm
452 mm
4.3 kg
Power consumption, electrical specifications and acoustic emissions
Power usage drops significantly while in Ready or Sleep mode, which saves natural resources and saves money without affecting the high performance of this product.
AC power
Sleep
Off
On/Ready (Flatbed scanning)
On/Ready (Duplex Automatic Document Feeder scanning)
HP ScanJet Pro 2500
AC110V
1.8 W
0.2 W
10.7 W at 300dpi
8.8 W at 600dpi
15.3 W at 300dpi
10.6 W at 600dpi
HP ScanJet Pro 2500
AC230V
1.69 W
0.16 W
11 W at 300dpi
9.2 W at 600dpi
15.9 W at 300dpi
10.9 W at 600dpi
Operating environment range
This product is intended to be supplied by a Listed Power Unit, marked with LPS or Limited Power Source. The power supply is rated 100–240V~, and has a DC output of 24 Vdc, 1.5 A, 36 W.
Name
Temperature
Operating the scanner: 10° to 35° C
Storage: -40° to 65° C
Relative humidity
Operating the scanner: 10% to 80% noncondensing 10° to 35° C
Storage: up to 90% at 0° to 65° C
