Document ID: c04866021
Version: 1
System BIOS Update 01.12 for HP ZBook 17 G2 and ZBook 15 G2
Release date : 26-Oct-2015
Last updated : 26-Oct-2015
DETAILS OF CHANGE
  • Provides support for Windows 10.
  • Enables password protection for the F9 (boot options) and F12 (network boot) options in the BIOS startup menu.
  • Fixed an intermittent issue where the Hybrid Graphics option is missing from the F10 (BIOS) Setup menu.
  • Fixes an issue where the computer does not power on properly when Secure Boot and Computrace support are enabled at the same time.
  • Fixes an issue where the computer does not boot properly from the M2.PCIE drive when certain encryption applications are enabled.
  • Fixes an intermittent issue where the computer may blue screen after performing a system reboot.
  • Provides the following updated NVIDIA VBIOS:
    • N15PQ1, version 80.07.EF.00.03
    • N15PQ3, version 80.06.8A.00.03
    • N15PQ5, version 82.07.80.00.05
    • N15MQ2, version 80.28.96.00.04
  • Provides the following updated AMD VBIOS:
    • M6100, version 45331.003
    • M5100, version 46191.001
REASON FOR CHANGE
Quarterly refresh for factory and Web release only.
IMPACT OF CHANGE
  • The updated BIOS provides support for new Hynix VRAM for NVIDIA graphics platforms.
  • The updated BIOS provides support for new Micron/Elpida VRAM for AMD graphics platforms.
Components affected:
HP ZBook 17 G2 Mobile Workstation and HP ZBook 15 G2 Mobile Workstation
DATE OF CHANGE
Effective date : 29-Sep-2015
Hardware platforms affected : HP ZBook 15 G2 Mobile Workstation, HP ZBook 17 G2 Mobile Workstation
