HP Printers - Printing With Windows 10 Mobile
This document is for HP printers, smartphones and tablets running Windows 10 Mobile.
Print from your Windows 10 Mobile device to many HP printers using the built-in printing solution.
Print with Windows 10 Mobile
Print emails, images, documents, or web pages from your Windows 10 Mobile device to your HP printer.
  1. Make sure the printer is connected to the same wired (Ethernet) or wireless network with an active Internet connection as your Windows 10 Mobile device.
    • If your printer is connected with a wired (Ethernet) connection, check the cable and the lights on the printer’s Ethernet port. The green link light should be steady, and the orange activity light should blink when the cable is connected.
    • If your printer is connected with a wireless connection, make sure the wireless feature is on, and the printer is connected to the same network as your computer.
      Some printers have a wireless icon and a blue light on the front of the printer. Make sure the light is on and not blinking.
  2. On your Windows 10 Mobile device, open the Wi-Fi settings and make sure you are connected to your network.
  3. Open the app that has the item that you want to print.
  4. Tap the Print icon .
  5. From the print preview screen, select your printer, change any print settings, then tap Print.
Find answers to frequently asked questions about printing from your Windows 10 Mobile device.
