HP Pavilion Notebook - 15-ab113no (ENERGY STAR) Product Specifications
P4A55EA
AMD Quad-Core A10-8700P APU with Radeon™ R6 Graphics (1.8 GHz, up to 3.2 GHz, 2 MB cache)
Flash cache
8 GB
12 GB DDR3L SDRAM (1 x 4 GB, 1 x 8 GB)
Video Graphics
AMD Radeon R7 M360 Graphics (2 GB DDR3 dedicated)
Hard Drive
1 TB 5400 rpm SATA SSHD
Optical drive
SuperMulti DVD burner
39.6 cm (15.6") diagonal FHD IPS anti-glare WLED-backlit (1920 x 1080)
Display size (diagonal)
39.6 cm (15.6")
Keyboard
Full-size island-style keyboard with integrated numeric keypad
Pointing device
Wireless Connectivity
802.11a/b/g/n/ac (1x1) and Bluetooth® 4.0 combo (Miracast compatible)
External Ports
1 HDMI; 1 headphone/microphone combo; 1 USB 2.0; 2 USB 3.0; 1 RJ-45
38.45 x 26.11 x 2.52 cm
2.29 kg
65 W AC power adapter
4-cell, 41 Wh Li-ion
HP TrueVision HD Webcam (front-facing) with integrated dual array digital microphone
B&O PLAY; Dual speakers
Pre-installed software
Evernote; Netflix; Skype
HP Games by WildTangent; HP Lounge; HP 3D DriveGuard
