HP LaserJet Pro M402, M403, MFP M426, MFP M427 - Removal and replacement: 250-sheet paper input tray
This document provides the procedures to remove and replace Tray 2.
Before performing service
Turn the printer power off
  • Disconnect the power cable.
      warning:
Use the table below to identify the correct part number for your printer. To order the part, go to www.hp.com/buy/parts.
Tray 2 part number
RM2-5392-000CN
Cassette (Tray 2) assembly
Required tools
  • No special tools are required to remove this part.
After performing service
Turn the printer power on
  • Connect the power cable.
Post service test
Make sure that the printer initializes to a Ready state.
Print a configuration page (from Tray 2) to make sure that the printer is functioning correctly.
Step 1: Remove Tray 2
  1. Pull the tray straight out of the printer to remove it.
    Figure : Remove the tray
Step 2: Unpack the replacement assembly
Unpack the replacement part from the packaging.
Recycle and unpack
Figure : Recycle and unpack
Step 3: Install Tray 2
  1. Slide the tray straight into the printer to install it.
    Figure : Install the tray
