    Apache Log4j Update
HP ProOne 600 G2 21.5-inch All-in-One Business PC - Overview
Figure : HP ProOne 600 G2 21.5-inch All-in-One Business PC
Product overview
Feature
Weight (unboxed)
Without stand: 6.38 - 6.58 kg (14.05 - 14.49 lb)
With easel stand: 7.06 - 7.26 kg (15.55 - 15.99 lb)
With adjustable height stand: 10.18 - 10.38 kg (22.42 - 22.86 lb)
With recline stand: 9.44 - 9.64 kg (20.79 - 21.23 lbs)
Dimensions (W x D x H)
Without stand: 531.45 x 371.8 x 58.7 mm (20.92 x 14.63 x 2.31 in)
With easel stand: 531.45 x 371.8 x 148.72 mm (20.92 x 14.63 x 5.85 in)
With adjustable height stand: 531.45 x 531.44 x 209.95 mm (20.92 x 20.92 x 8.27 in)
With recline stand: 531.45 x 429.85 x 278.36 mm (20.92 x 16.92 x 10.96 in)
