Document ID: c04784086
Version: 1
Advisory: HP Elite x2 1011 G1 - Cannot Toggle Airplane Mode Using Fn+F12 Keys After Performing System Recovery
Release date : 02-Sep-2015
Last updated : 02-Sep-2015
DESCRIPTION
After performing an F11 system recovery, the Fn+ F12 key combination fails to switch the computer into or out of Airplane mode.
SCOPE
Computers:
HP Elite x2 1011 G1
Operating Systems:
  • Microsoft Windows 10 Pro (64-bit)
  • Microsoft Windows 10 Pro (32-bit)
  • Microsoft Windows 10 Home (32-bit)
  • Microsoft Windows 10 Mobile
  • Microsoft Windows 10 Home (64-bit)
  • Microsoft Windows 10 Enterprise (64-bit)
RESOLUTION
The Fn+F 12 keys cannot be used to toggle Airplane Mode on or off. There are alternative methods including using the Action Center:
  1. Click or tap Network settings in the task tray.
  2. Click or tap the Airplane mode tile to toggle on or off.
    Figure : Network and airplane mode settings
    Network and airplande mode settings highlighted in red
  1. Network settings
  2. Airplane mode
Airplane mode can also be turned on and off from the Action Center and from network settings in the control panel.
Hardware platforms affected : HP Elite x2 1011 G1
Support Communication Cross Reference ID : IA04784086
