Document ID: c04784084
Version: 1
Advisory: HP ProBook 455 G2 Notebook PC - IPM+ Cannot Control Display Brightness When Computer Running on Battery
Release date : 02-Sep-2015
Last updated : 02-Sep-2015
DESCRIPTION
Adjusting the display brightness using IPM+ while the computer is running on battery has no effect on the display brightness.
The issue may occur after upgrading the operating system to Windows 10.
SCOPE
Information in this document applies to HP Probook 455 G2 Notebook PCs.
RESOLUTION
Install the latest graphics driver to resolve the issue.
SoftPaq Description
Release Notes
Download SoftPaq
AMD Video Driver and Control Panel
Version: 1335210041009140605A17288
Revision: C Pass: 1
NOTE: A more recent version of this software may be available. Check for newer versions at http://www.hp.com/.
Hardware platforms affected : HP ProBook 455 G2 Notebook PC
Support Communication Cross Reference ID : IA04784084
