HP Notebook PCs - A Strange Noise Is Heard From the Speakers When Using Audio Recording Software
When the Microsoft camera application and another audio application are running at the same time, a strange noise is heard from the speakers.
To prevent the noise while using the other audio application, end task on the Microsoft Camera application.
The Microsoft camera switches to background mode when the "X" is selected to close the application. The application needs to be closed with Windows Task Manager.
Use the following instructions to close the application in Windows Task Manager:
  1. Close the Microsoft camera application by pressing the X in the upper right corner.
  2. Press the Ctrl+Alt+Del keys.
  3. Select Task Manager.
  4. Select the Microsoft Camera, and then click End Task.
  5. Close Task Manager
Country: Flag Serbia
