HP LaserJet Enterprise MFP M630 - Load Tray 1
The following information describes how to load paper in Tray 1.
To avoid jams, never add or remove paper from Tray 1 during printing.
  1. Open Tray 1.
    Figure : Open Tray 1
  2. Pull out the tray extension to support the paper.
    Figure : Pull out the tray extension
  3. Load paper in the tray. For information about how to orient the paper, see Tray 1 paper orientation.
    Figure : Load paper
  4. Make sure that the paper fits under the fill line on the paper guides.
    The maximum stack height is 10 mm, or approximately 100 sheets of 75g paper.
    Figure : Stack-height limit
  5. Adjust the side guides so that they lightly touch the paper stack, but do not bend it.
    Figure : Adjust the guides
Paper type
Paper size (one-sided printing)
Paper size (two-sided printing)
Single-sided printing, no stapling mailbox
Duplex printing, no stapling mailbox
Single-sided printing, with the stapling mailbox
Duplex printing, with the stapling mailbox
Letterhead, preprinted, or prepunched
Letter, Legal, Executive, Statement, Oficio (8.5 x 13), 3 x 5, 4 x 6, 5 x 7, 5 x 8, A4, A5, A6, RA4, B5 (JIS), B6 (JIS), 10 x 15 cm, Oficio (216 x 340), 16K 195 x 270 mm, 16K 184 x 260 mm, 16K 197 x 273 mm, Japanese Postcard (JIS), Double Japan Postcard Rotated (JIS), custom sizes
Letter, Legal, Executive, Oficio (8.5 x 13), A4, A5, RA4, B5 (JIS), Oficio (216 x 340), 16K 195 x 270 mm, 16K 184 x 260 mm, 16K 197 x 273 mm, custom sizes
Face-up
Top edge leading into the product
Face-down
Bottom edge leading into the product
Face-up
Face-down
Envelopes
Envelope #9, Envelope #10, Envelope Monarch, Envelope B5, Envelope C5, Envelope C6, Envelope DL
Face-up
Short, postage-edge leading into the product
Face-up
