HP Color LaserJet Enterprise M651, MFP M680 - Load Tray 2 and the 500-sheet trays
The procedure to load paper for the 500-sheet trays is the same as for Tray 2. Only Tray 2 is shown here.
  1. Open the tray.
    Do not open this tray while it is in use.
    Figure : Open the tray
  2. Adjust the paper-length and paper-width guides by squeezing the adjustment latches and sliding the guides to the size of the paper being used.
    Figure : Adjust the guides
  3. Load paper into the tray. Check the paper to verify the guides lightly touch the stack, but do not bend it. For information about how to orient the paper, see Tray 2 and the 500-sheet trays paper orientation.
    To prevent jams, do not overfill the tray. Be sure that the top of the stack is below the tray full indicator.
    If the tray is not adjusted correctly, an error message might appear during printing or the paper might jam.
    Figure : Load paper
  4. Close the tray.
    Figure : Close the tray
  5. The tray configuration message displays on the product control panel.
  6. Touch the OK button to accept the detected type and size, or touch the Modify button to choose a different paper size or type.
    For custom-size paper, you need to specify the X and Y dimensions for the paper when the prompt displays on the product control panel.
    Figure : X and Y dimensions
  7. Select the correct type and size, and then touch the OK button.
Paper type
Image orientation
Duplex mode
Paper Size
How to load paper
Preprinted or letterhead
Portrait
1-sided printing
Letter, Legal, Executive, Oficio (8.5 x 13), A4, A5, RA4, B5 (JIS), Oficio (216 x 340), 16K 195 x 270 mm, 16K 184 x 260 mm, 16K 197 x 273 mm, custom sizes
Face-up
Top edge at the left side of the tray
Automatic 2-sided printing
Face-down
Landscape
1-sided printing
Face-up
Top edge toward the back of the tray
Face-down
Prepunched
Portrait or landscape
1- or 2-sided printing
Holes toward the back of the tray
