HP 4500, 4600 Inkjet Printers - Wireless Printer Setup (Windows)
This document is for computers with Windows and the following printers:
  • HP DeskJet Ink Advantage 4535, 4536, 4538, 4675, 4676, and 4678 All-in-One printers
  • HP ENVY 4510 (series), 4511, 4512, 4513, 4516, 4520, 4521, 4522, 4523, 4524, 4525, 4526, 4527, and 4528 All-in-One printers
  • HP OfficeJet 4650, 4652, 4654, 4655, 4656, 4657, and 4658 All-in-One printers
To set up an HP printer on a wireless (Wi-Fi) network, connect the printer to the network, and then install the print driver and software.
Step 1: Prepare for installation
Before setting up the printer on your wireless network, gather the network name and password, and then turn on your router, printer, and computer.
If you need to find your network password, go to How to Find the WEP or WPA Key or Password for Your Wireless Network.
  1. Gather the following items:
    • Network name: The network name is the SSID (Service Set Identifier).
    • Network password: The password might also be called the WEP key or WPA security passphrase.
    • A computer connected to your wireless network
    • Internet access: HP recommends broadband Internet access such as cable or DSL for software downloads, using Web Services, and getting printer updates.
  2. Make sure the router and computer are turned on, and that the computer is connected to the same wireless network to which you want to connect the printer. Turn on the printer and place it close to the computer and within range of the router during the setup procedure.
  3. Disconnect any USB or Ethernet cables from the printer.
Step 2: Connect to the wireless network
Connect the printer to your network with the Wireless Setup Wizard so the HP installer can find the printer during the installation.
  1. Turn on the printer if it is not already on.
  2. On the printer control panel, touch the Wireless icon .
    The Wireless screen displays.
  3. Touch the Settings icon .
  4. Touch Wireless Setup Wizard, then follow the instructions on the control panel to connect the printer to your wireless network.
Step 3: Download and install the printer software
On the computer you want to print from, start the software installation, and then download and install the HP full feature print driver. It contains the wireless print drivers, as well as HP Printer Assistant software for scanning and other printer management functions.
  1. Go to 123.hp.com, type your model number, click Begin, and then click Download.
  2. Double-click the driver file with HP Easy Start in the name in the browser downloads bar or in the Downloads folder to start the installation.
  3. When prompted to choose your software and driver, select Full Software and Drivers, click Continue, and then follow the on-screen prompts to install the full feature print driver and complete the wireless setup.
Review these frequently asked questions on setting up the wireless network connection.
