    Apache Log4j Update
HP Pavilion Notebook 15-ab094tx Product Specifications
Product Name
15-ab094tx
Product Number
N1V38PA
2.2 GHz Intel Core i5-5200U with Intel HD Graphics 5500
Microprocessor Cache
3 MB cache, 2 cores
Memory
4 GB DDR3L-1600 SDRAM (1 x 4 GB)
Video Graphics
NVIDIA GeForce 940M (2 GB DDR3L dedicated)
15.6" diagonal HD BrightView WLED-backlit (1366 x 768)
Hard Drive
1 TB 5400 rpm SATA
Multimedia Drive
SuperMulti DVD burner
Network Card
Wireless Connectivity
802.11b/g/n (1x1) and Bluetooth 4.0 combo (Miracast compatible)
WiDi
Keyboard
Island-style Keyboard
Pointing Device
External Ports
1 USB 3.0
2 USB 2.0
1 HDMI
1 RJ-45
1 headphone/microphone combo
Dimensions
38.45 x 26.11 x 2.52 cm
Starting at 2.29 kg
Power
65 W AC power adapter
4-cell, 41 Wh Li-ion
HP TrueVision HD Webcam (front-facing) with integrated digital microphone
Operating System:
Windows 8.1 (64-bit)
