HP PCs - Understanding and Using Windows 10
This document is for HP computers with Windows 10.
Read this document to learn and discover more about the features of Windows 10.
Windows 10 is a dynamic environment where the Start screen is easily changed and graphics update frequently. Some graphics in this article might be different from your Windows 10 experience.
Upgrade to Windows 10
There are things you need to do before and after upgrading to Windows 10, such as backing up your important files or updating your hardware drivers.
The following documents provide this information as well as instructions on performing the upgrade.
Windows 10 features
Click an item in the following list for more information about the features in Windows 10.
Navigate in Windows 10
Use the information in the following sections to learn how to perform your tasks in Windows 10.
Use Windows 10 apps
Use the information in the following sections to learn how to use the Windows 10 apps.
Review the following frequently asked questions (FAQs) to learn more about the features of Windows 10.
