    Fix HP Printer issue on macOS
HP LaserJet Enterprise M604, M605, M606 - Install the optional envelope feeder
This document provides the procedure to install the envelope feeder accessory for the HP LaserJet Enterprise M604, M605, M606 models.
Figure : Envelope feeder
  1. Complete the following steps to unpack the envelope feeder:
    1. Remove the tape from the outside of the envelope feeder.
      HP recommends recycling packing materials whenever possible.
      Figure : Remove the tape
    2. Open the tray extension.
      Figure : Open the tray extension
    3. Remove the packaging materials from inside the envelope feeder, and then close the tray extension.
      Figure : Remove the packing materials from inside the envelope feeder
  2. Press the Power button to turn off the printer.
    Figure : Turn off the printer
  3. Grasp the handle on each side of Tray 1, and pull it forward to open it.
    Figure : Open Tray 1
  4. Remove the envelope cover.
    Figure : Remove the envelope cover
  5. Align the envelope feeder with the slots on the printer, and then install the envelope feeder.
    Figure : Install the envelope feeder
  6. Lower the envelope tray extension (callout 1), and then lift the envelope weight (callout 2).
    Figure : Lower the envelope tray extension and lift the envelope weight
  7. Load envelopes into the envelope feeder.
    Figure : Load the envelopes
  8. Adjust the envelope width-guides to the correct size for the envelopes that are loaded in the tray.
    Figure : Adjust the envelope width-guides
  9. Lower the envelope weight.
    Figure : Lower the envelope weight
  10. Press the Power button to turn on the printer.
    Figure : Turn on the printer
  11. OS X: The list of installed options should automatically update during the first print job after installing the accessory. If not, perform the following steps:
    1. From the Apple menu, click System Preferences.
    2. Select Print & Scan (or Printers & Scanners).
    3. Select the printer, select Options & Supplies, and then select Driver.
    4. Manually configure the accessory.
    Windows 8.0 and 8.1: When attaching the accessory after installing the printer software, perform the following steps:
    1. Scroll to the bottom-left corner of the screen, and right-click the window that displays.
    2. Select Control Panel. Under Hardware and Sound, select View devices and printers.
    3. Right-click the name of the printer, and then select Printer Properties.
    4. Click the Device Settings tab.
    5. Click the Installable Options section, if Automatic Configuration is present, select Update Now. If the Automatic Configuration option is not present, manually install the accessory by opening the appropriate category and selecting the accessory.
    Windows XP, Windows Vista® and Windows 7: When attaching the accessory after installing the printer software, perform the following steps:
    1. Make sure the printer is turned on and connected to the computer or network.
    2. Open the Windows Start menu, and then click Devices and Printers (or Printers and Faxes for XP).
    3. Right-click the name of the printer, and select Printer Properties (or Properties for XP).
    5. Click the Installable Options section.
    6. In the drop-down box next to Automatic Configuration, select Update Now.
