HP Scanjet Enterprise Flow 5000 s3 - Scanner specifications
Name
Scanner type
Duplex sheet-feed scanner
Size
Width: 310 mm, Depth: 183.8 mm, Height: 182.4 mm
4.82 kg
Scanning element
Contact image sensor (CIS)
Interface
USB 2.0 high speed (compatible with USB 1.1)
Optical resolution
600 x 600 dpi hardware
Power adapter information
  • This product is intended to be supplied by a Listed Power Unit, marked with LPS or Limited Power Source and rated O/P: 32 Vdc, 1.56 A (1560 mA).
  • DC output for power supply: 32 Vdc, 1.56 A (1560 mA), 50W
Power consumption
For power consumption information, see the HP Scanjet Enterprise Flow 5000 s3 regulatory supplement .pdf file on the HP Scanning Software CD.
System requirements
To view minimum and recommended system requirements, go to www.hp.com, select your country/region, search on your scanner model, and then search on datasheet.
Country: Flag Serbia
