Document ID: c04622980
Version: 1
Advisory: HP ElitePad 1000 G2 Tablet - the Tablet Loses Wireless Wide Area Network (WWAN) Connection
Release date : 27-Mar-2015
Last updated : 27-Mar-2015
DESCRIPTION
The tablet may lose WWAN connectivity. The issue occurs because the HP lt4111 mobile broadband module driver has been deleted by Windows.
SCOPE
Computers:
WWAN module:
HP lt4111 Mobile Broadband Module
Operating Systems:
  • Microsoft Windows 8.1 (Standard)
  • Microsoft Windows 8.1 Pro
  • Microsoft Windows 8.1 (Enterprise)
RESOLUTION
Correct the issue if it has already occurred and prevent the issue from occurring by running all of the following SoftPaq executables:
  1. If the issue has already occurred, power the computer off and then back on.
    NOTE: this must be done, if the issue has already occurred, so that Windows can re-detect the lt4111 WWAN module. Otherwise, the driver cannot be installed.
  2. Reinstall the HP lt4111 Mobile Broadband Module driver (even if the issue has not occurred).
    IMPORTANT! You must run the lt4111.exe installer to ensure that the drivers and firmware are properly installed. Simply copying the .inf file will not work.
    SoftPaq Description
    Release Notes
    Download SoftPaq
    Sierra Wireless Driver Package for HP lt4111 Mobile Broadband Module
    Version: 5.0.1312.4027
    Revision: A Pass 1
  3. Install Essential System Updates for Microsoft Windows 8.1.
    SoftPaq Description
    Release Notes
    Download SoftPaq
    Version: 1.0
    Revision: 1 Pass: 1
  4. Install System Default Settings for Windows 8.1.
    SoftPaq Description
    Release Notes
    Download SoftPaq
    Version: 2.1
    Revision: 1 Pass: 1
NOTE: More recent versions of the above software may be available. Check for newer versions at http://www8.hp.com/us/en/drivers.html.
Hardware platforms affected : HP ElitePad 1000 G2 Base Model Tablet, HP ElitePad 1000 G2 Tablet, HP ElitePad 1000 G2 Tablet, HP ElitePad 1000 G2 Tablet (ENERGY STAR)
Support Communication Cross Reference ID : IA04622980
