Specification
Model
K7X26AA
Type
19.53 in VA with LED backlight
Viewable image area
(diagonal)
49.6 cm (19.53 in) widescreen
Panel active area (W x H)
43.48 x 23.86 cm (17.11 × 9.39 in)
Resolution
1920 x 1080 at 60 Hz
Aspect ratio
16:9
Viewing angle
Up to 178° horizontal / 178° vertical typical
Brightness
250 cd/m2
Contrast ratio
(typical)
3000:1 Static; 5,000,000:1 Dynamic (DCR)
Response time
(typical)
8 ms gray to gray
note: |
Pixel pitch
0.2265 (H) x 0.221 (V) mm
Pixels per inch (PPI)
113 DPI
Backlight lamp life
(to half brightness)
30,000 hrs min
Color gamut (typical)
72%
Color support
Up to 16.7 million colors with the use of FRC technology
- ${title}
- ${title}
- ${title}
- ${title}
HP ProDisplay P202va 19.53-inch Monitor - Specifications
Panel Specifications
User Controls
Specification
Buttons or switches
Menu
Minus ("-")
Plus ("+")
"OK"
Power
Languages
10 (English, Spanish, French, Portuguese, Russian, Simplified Chinese, Traditional Chinese, Korean, German, Japanese)
On Screen Display (OSD) User Controls
Brightness, Contrast, Color, Image Control, OSD Control, Management, Language, Information, Factory Reset, Source Control, Exit
Signal Interface / Performance
Specification
Horizontal frequency
24-96 kHz
Vertical frequency
50-76 Hz
Native resolution
Preset graphic modes
1920 X 1080 at 60 Hz
1680 X 1050 at 60 Hz
1600 X 900 at 60 Hz
1440 X 900 at 60 Hz
1280 X 1024 at 60 Hz
1280 x 800 at 60 Hz
1280 X 720 at 60 Hz
1024 X 768 at 60 Hz
800 X 600 at 60 Hz
720 X 400 at 70 Hz
640 X 480 at 60 Hz
Maximum pixel clock speed
170 MHz
Anti-glare
Yes
Video / Other Inputs
Plug and play
Yes
Input connectors
DisplayPort 1.2 - 1
VGA
HDCP support on DisplayPort - 1
USB
N/A
Video cables included
VGA 1.8 m (5.9 ft) - 1
Audio
N/A
Power
Specification
Power supply
Internal
Input power
100 - 240 VAC 50/60 Hz
Maximum power
23 W
Typical power
18.5 W
Sleep power
0.5 W
Power cable length
1.9 m (6.2 ft)
Mechanical
Specification
Dimensions (W x D x H)
Unpacked with stand:
47.41 x 17.59 x 35.76 cm
(18.66 x 6.92 x 14.08 in)
Unpacked without stand (head only):
47.41 x 5.3 x 29.21 cm (18.66 x 2.09 x 11.5 in)
Packaged:
53.7 x 12.6 x 36.5 cm (21.14 x 4.96 x 14.37 in)
Head only:
2.6 kg (5.72 lb)
3.3 kg (7.26 lb)
Packaged:
4.4 kg (9.7 lb)
Ergonomic Features
Specification
Detachable stand
Yes, ships detached
Height adjustment
N/A
Tilt range
-5° to + 22° vertical
Swivel
N/A
Pivot
N/A
Environmental
Specification
Temperature
Operating: 5° to 35° C (41° to 95° F)
Non-operating: –20° to 60° C (-4° to 140° F)
Humidity
Operating: 20% to 80% non-condensing
Non-operating: 5% to 95%, 38.7° C max wet-bulb
Altitude
Operating: 0 to 5,000 m (0 to 16,404 ft)
Non-operating: 0 to 12,192 m (0 to 40,000 ft)
White LED backlights
Yes
CCFL panel
No
Arsenic-free display glass
Yes
Low halogen
Yes (except cables)
Mercury-free display backlighting
Yes
Options
Specification
HP Adjustable Dual Display Stand—Part Number AW664AA
Premium space-saving dual screen solution provides access to more monitor real estate and makes it possible to manage multiple applications simultaneously. Weight adjustable for dual monitors from 17-24 inches. Rotate displays into portrait/landscape positions.
HP Integrated Work Center for Desktop Mini and Thin Client—Part Number G1V61AA
Make the most of small work spaces with an HP IWC Desktop Mini/Thin Client that lets you create a compact desktop solution by combining a compatible display up to 24 diagonal inches with your choice of compatible platform to give you convenient front access to all of its inputs.
HP DisplayPort Cable Kit —Part number VN567AA
Connects a DisplayPort connector on an HP Business Desktop computer to a DisplayPort connector on a monitor
HP LCD Monitor Quick Release — Part number EM870AA
An easy-to-use, VESA-compliant, LCD monitor mounting solution that allows you to quickly and securely attach an LCD monitor to a variety of stands, brackets, arms or wall mounts. For more information, refer to this product's QuickSpecs document.
HP Business PC Security Lock Kit — Part number PV606AA
Attaches to the rear of the PC with a six-foot steel cable that can be used to secure a PC or peripherals such as mice, keyboards, monitors or USB security devices to protect them against unauthorized removal by physically connecting the system to an anchor point.
What's in the Box?
Specification
Monitor and accessories
AC power cord 1.9 m (6.2 ft)
VGA cable 1.8m (5.9 ft)
Documentation
CD (includes user guide, warranty, drivers)
HP Display Assistant
Miscellaneous
Specification
User guide languages
English, Arabic, Simplified Chinese, Traditional Chinese, Czech, Danish, Dutch, Finnish, French, German, Greek, Hungarian, Italian, Japanese, Kazakh, Korean, Norwegian, Polish, Brazilian Portuguese, Russian, Slovenian, Spanish, Swedish and Turkish
Warranty languages
Color
Black
VESA mounting
100 mm VESA mount
Security lock-ready
Yes
Country of origin
China
Certification and compliance
TCO Certified, CEL Grade 1, Microsoft WHQL Certification (Windows 8.1 and Windows 7), ENERGY STAR Qualified, EPEAT Gold, CE, CB, KC, KCC, NOM, PSB, ICE, TUV-S, ISO 9241-307, EAC, UL, CSA, PSB, ISC, CCC, CEL, CECP, SEPA, ISC, VCCI, FCC, BSMI, Vietnam MEPS, Australian-New Zealand MEPS, WEEE
Compatibility
Compatible with platforms using the VESA standard video modes. Recommended for use with HP products.
Service and warranty
Protected by HP, including a 3 year standard limited warranty. Optional HP Care Pack Services are extended service contracts that extend your protection beyond the standard warranties.
Link to Product Overview Page
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Serbia
- ${title}
hp-hero-support-search
- ${title}
