Remove and Replace the Touch Panel Kit for Sprout by HP
This document applies to Sprout by HP.
Sprout by HP
Before you begin
  • You need a Phillips head screwdriver.
  • Remove all CDs and DVDs from the optical drive.
  • Turn off the computer, and disconnect all cables. Be sure to disconnect the network cable before disconnecting the power cord.
  • Place the computer face-down on a soft flat surface. HP recommends that you place the Sprout on a blanket, towel, or other soft cloth to protect the touch screen surface from scratches or other damage.
  • Do not remove a component from the protective packaging until you are ready to install it.
  warning:
Procedures in this document are provided by HP for qualified service agents and as a courtesy to its customers. Servicing internal components increases the risk of damaging the computer which might not be covered under warranty. Understand the risk and refer to the product's warranty before attempting to service the computer.
Video overview
For best quality on dial-up connections, wait until the video has fully loaded before viewing.
Remove the touch panel kit
To remove the touch panel kit, first remove the touchmat, the right and left rear covers, the column assembly, the bottom rear cover, the motherboard EMI shield, and several other components using the following instructions:
Step 1
Remove the motherboard EMI shield.
For detailed instructions to remove the motherboard EMI shield, see the HP support document, Remove and Replace the motherboard EMI shield for HP Sprout by HP.
Removing the motherboard EMI shield
Step 2
Remove the top rear cover.
To remove the top rear cover, pry loose the top edge of the top rear cover and lift and remove it from the computer.
Removing the top rear cover
Step 3
Remove the pink torx head screw that secures the microphone bracket to the top of the computer.
Removing the pink torx head screw
Step 4
Partially pull the microphone assembly out of the computer, placing it to the side.
Partially removing microphone assembly
Step 5
Remove the pink torx head screw that secures the webcam assembly to the computer.
Step 6
Pull up on the edges of the webcam bracket, and partially pull the webcam assembly out of the computer, placing it to the side.
Partially removing webcam assembly
Step 7
Remove the two silver torx head screws that secure the right side I/O board to the middle frame.
Two screws that secure the I/O board to the frame
Step 8
Pull up on the edges of the right side I/O board, and partially pull the right side I/O board out of the computer, placing it to the side.
Partially removing the right side I/O board
Step 9
Remove the two silver torx head screws that secure the left side I/O board to the middle frame.
Two screws that secure the left side I/O board to the middle frame
Step 10
Tip up the inside edge of the board, and partially pull the left side I/O board out of the computer, placing it to the side.
Partially removing the left side I/O board
Step 11
Find the two backlight connector cable guides.
Two backlight connector cable guides
Step 12
Release the panel backlight connector from its cable guides on the middle frame.
Releasing  backlight connector cable
Step 13
Detach the backlight connector from the touch panel (see the video if needed).
Backlight connector location
Step 14
Squeeze the sides of the LVDS connector on the touch panel (via the access hole near the system blower) to detach the LVDS connector from the panel.
Detaching the LVDS connector
Step 15
Remove the screws that secure the middle frame to the touch panel kit. Each screw is marked with a stencil of an arrow with a single circle inside.
Remove the twelve black self tapping screws...
Twelve black screws
...and then remove the four pink machine screws.
Four pink screws
Step 16
Remove the speakers interconnector from its cable guide on the front bezel.
Removing speakers interconnector
Step 17
Partially tip up the bottom of the middle frame.
Tipping up bottom of middle frame
Step 18
Carefully remove the connector from the touch control board on the back of the panel.
Touch control board connector
Step 19
Fully remove the middle frame from the touch panel assembly.
Removing middle frame from touch panel assembly
Replace the touch panel kit
Use the following steps to replace the touch panel kit:
Step 1
Before replacing the touch panel kit, notice it consists of the panel with the front bezel attached...
Touch panel with attached front bezel
...and the touch control boards with their flat ribbon connector.
Touch control boards with their flat ribbon connector
Step 2
To replace the touch panel kit, place the touch panel assembly face down on a soft flat surface.
Touch panel assembly face down on soft flat surface
Step 3
Align the top of the middle frame assembly over the touch panel.
Aligning top of middle frame assembly over touch panel
Step 4
Connect the touch control board connector to the board.
Connecting the touch control board connector to the board
Step 5
Lower the middle frame assembly into place.
Lowering middle frame assembly into place
Step 6
Replace the speakers interconnector into its cable guide on the front bezel.
Replacing speakers interconnector
Step 7
Replace the screws that secure the middle frame to the touch panel kit. Each screw is marked with a stencil of an arrow with a single circle inside.
Replace the twelve black self tapping screws...
Twelve black screws
...and replace the four pink machine screws.
Four pink screws
Step 8
Replace the LVDS connector to the panel.
Replacing LVDS connector
Step 9
Replace the backlight connector to the panel (see the video if needed).
Step 10
Step 11
Replace the backlight connector into its cable guides on the middle frame.
Replacing backlight connector cable
Step 12
Make sure the backlight connector is inserted into the port on the board that matches the LCD panel manufacturer...
Backlight connector ports
...note that a stencil next to each port indicates the location per panel manufacturer.
Stencils for panel manufacturer ports
Step 13
Set the jumpers on the converter board to match the configuration for the panel manufacturer...
Jumpers on the converter board
...note that the jumper configuration for each panel manufacturer is stenciled on the board itself...
...as well as on the middle frame right above the board.
Stencils of jumper configuration on the board
Stencils of jumper configuration on middle frame
Step 14
Replace the left side I/O board.
Replacing left side I/O board
Step 15
Secure the left side I/O board by replacing the two silver torx head screws.
Step 16
Replace the right side I/O board.
Replacing right side I/O board
Step 17
Secure the right side I/O board to the middle frame by replacing the two silver torx head screws.
Two screws that secure the I/O board to the middle frame
Step 18
Replace the webcam assembly.
Replacing webcam assembly
Step 19
Replace the pink torx head screw that secures the webcam assembly to the computer.
Replacing the pink torx head screw
Step 20
Replace the microphone assembly.
Replacing the microphone assembly
Step 21
Replace the pink torx head screw that secures the microphone bracket to the top of the computer.
Step 22
Replace the motherboard EMI shield and the remaining components.
For detailed instructions to replace the motherboard EMI shield and the remaining components, see the HP support document, Remove and Replace the motherboard EMI shield for HP Sprout by HP.
Replacing the motherboard EMI shield
