HP LaserJet Enterprise M4555 MFP printers - 13.C3.A2 error
Issue:
A 13.C3.A2 paper jam error appears on the control panel when paper is jammed before it exits the printer, or as it enters the stapler/stacker.
Solution
Check the printer for jammed paper and clear the jam, if needed.
Step 1: Clear the paper jam
  1. Turn the printer off.
  2. If the paper is visible from the output bin, grab the leading edge and remove it.
    Figure : Location of output bin
  3. For printers with a stapler/stacker, complete the following steps.
    1. Disconnect the stapler/stacker connector.
      Figure : Disconnect the stapler/stacker
    2. Press the release latch, and then slide the stapler/stacker away from the printer to remove it.
      Figure : Remove the stapler/stacker
    3. If the jammed paper is visible, pull it straight out.
  4. All other models: slide the output bin away from the product to remove it.
    Figure : Remove the standard output bin
  5. Slide the duplexer away from the printer to remove it.
    Figure : Remove the duplexer
  6. Carefully flex the left-hand side of fuser-entrance guide to release it, and then rotate the guide out and away from the printer to remove it.
    The fuser can be hot. Turn off the printer, and then wait for the fuser to cool.
    Figure : Remove the fuser-entrance guide
  7. Squeeze the two blue tabs on the fuser to release it, slightly lift it up, and then pull the fuser straight out of the printer to remove it.
  8. Clear the jam by carefully pulling the paper straight out.
    Figure : Remove jammed paper
  9. Push the fuser straight into the printer until it snaps into place.
    Figure : Reinstall the fuser
  10. Insert the right-hand side of fuser-entrance guide into the printer, carefully flex the left-hand side of the guide, and then push it back into the printer until the pins on the guide snap into the holes on the printer chassis.
    Figure : Reinstall the duplex-paper feed guide
  11. Slide the duplexer into the printer to install it.
    Figure : Reinstall the duplexer
  12. Models with a stapler/stacker: slide the stapler/stacker toward the product until it latches into place to install it.
    Figure : Reinstall the stapler/stacker
  13. Models with a stapler/stacker: reconnect the stapler/stacker connector.
    Figure : Reconnect the stapler/stacker
  14. All other models: slide the output bin toward the printer to install it.
    Figure : Reinstall the standard output bin
  15. Pull the top cover release lever to open the top cover.
    Figure : Open the top cover
  16. Remove any jammed sheets that are visible in the print cartridge area.
  17. If no jammed paper is visible, remove the print cartridge, and then remove any jammed paper in the paper path.
  18. If jammed paper is visible under the registration shield, use the green lever to raise the shield, and then clear the jam by gently pulling the paper straight out.
  19. Lower the shield, reinstall the print cartridge, and then close the top cover.
    Figure : Close top cover
  20. Turn the printer on.
Step 2: Contact HP
If the issue persists, contact HP technical support to perform additional troubleshooting steps.
